97 Yamaha 200 V6 carbureted.
I got fuel dripping off of the lower bolt on the starter. At first I thought it was oil...there are a couple oil lines that run thru that area....but it smells like gas,looks like gas and tatse like gas.
No fuel lines in that area except for small hoses that run from the Reed plate back to the block. I have had a issue in the past with those return lines coming off the nipples but I replaced them all and fastened them with zip ties
Going pull the starter and see if I can trace it. Of course I won't be able to run it with the starter off. Anyone have any ideas ?
Bill
Bill
