Command link is showing a speed of 63mph with the boat sitting on the trailer in the yard. Engines are f300s if that makes any difference. What should I try to get this thing to act right?
Command link lcd speed WAY off
I'm guessing you have a sensor which converts pitot tube water pressure to Command Link speed - and there is either a blockage in the pitot tube - or in the sensor - which is causing the bad reading.
but perhaps not
does your Command Link gauge tell you the time?
reason I ask - if you had time, it would mean it was connected to a GPS -
which should be giving you your speed - not a pitot tube
No time so I guess its the tube. I'm not gonna bother with it. Now I just need to figure out how to connect to my nss evo 2.
ÂÂÂÂÂÂÂÂÂÂÂÂÂÂÂ
