Hi. I am greasing all the fittings on this 1993 2 cycle 115. I see 6 fittings, confirmed with the owners manual. Four are at the pivot point. One is on the starboard side close to the bottom of the middle leg and one is just below the power head inside the cover.
They all took grease except no grease showed up at the top of the middle leg. However, grease came out of the bottom of the middle leg.
There is some dried grease at the top of the middle leg which I cleaned off. I'm going to try work in more grease on a hot day but should I be injecting grease through the fitting on the side near the bottom of the middle leg, or the one that is just below the power head? Not sure which fitting is the correct one to work on. Thanks. Greg.
