I was running my skiff when it bogged down a bit. When lowered to under 1/2 throttle it was ok. Eventually the motor quit and it blew some white smoke out if the exhaust.
I let it sit for a bit and went to ck the oil with the dip stick. When pulled the dip stick, oil pushed out like a fountain! After a tow and the boat sitting overnight, the same thing happened when I pulled the dip stick today
Is there a PVC valve on these or some other pressure relief valve that may be blocked? The oil was clear and looked like it was new. No water or fuel intrusion that I could see.....
