Unique issue for sure.
Buzzer wont stop on 1997 60HP Autolube (60FETO)
Thanks for all the help so far guys, its really appreciated. OK, so it gets a bit weirder... Today I decided to start the engine and disconnect the main wire harness coupler (leading to the remote control box), BAM, no more limp mode!. So I reconnected the main wire harness and begin stripping the con*****er one wire as a time until nothing was plugged in at all, just a bunch of disconnected cables.. to my surprise limp mode was still active!, I disconnected the wire harness again to make sure and it was no shock that limp mode had gone away. At this point I m pretty sure its the con*****er cable at fault, perhaps a split inside somewhere causing a ground. Tomorrow I m going to salvage the coupler and make my own loom to the control box but i m pretty sure this is gonna resolve the issue. I m assuming making one will be far cheaper than buying! I ll keep you guys posted tomorrow!!
