Hi Guys, really hoping you may be able to point me in the right direction. When I turn the key to the on position the alarm sounds wont stop (constant not beeping), if I run the engine it runs in limp mode and wont exceed 2000rpm. After reading many posts about it, I came to the conclusion that it was the oil tank sensor or temperature sensor. I pulled out the oil tank sensor so the float would drop and the alarm tone changed (alot louder), after putting it back in the buzzer returned to its normal tone so am assuming that it is functioning correctly. I have also tried disconnecting the pink wire from the temperature sensor but that also mad no difference, In a last ditch attempt, I disconnected the oil tank wiring loom and the temperature sensor combined but the buzzer is still sounding and engine runs in limp mode... Please help me
