Hi
I'm new to this forum and of course looking for some advice. I have a 2005 f25 Yamaha outboard that I have been running for the last 6 years without any major issues. My annual maintenance is new plugs oil changes (upper and lower), fuel filter and water separator filter. With the exception of a flat spot when accelerating it has run like a top.
This spring after my maintenance ritual(this year I put in a finer water separator filter) I had a tough time starting it and at low speeds it would idle rough and occasionally stall. I ran a gallon of gas (93 octane) mixed with a generous amount of Sea Foam carb cleaner. for a while I thought it did the trick but on my last fishing trip running the motor at low speed(*****ing) was lower than usual to the point of making little headway. Still it accelerated fine and ran perfectly above minimum speed.
First sorry for the long post. I tried not to leave anything out.
Where should I start carburetor or fuel pump?
thanks
thanks
