I have a question for rodbolt and the other top hands of this forum. I was running down lake this morning and my motor started missing and just quit, turns out the fuel line came loose from the bottom carb. Motor is 2001 Yamaha 115hp 2 stroke TLRZ. The line that came loose is a pre bent that goes on bottom of carb. It had a tye wrap on it but was broken when found off of carb. I would like to replace these fuel lines and I want to know if these should be ordered and just use the pre bent lines from Yamaha? I was surprised at why this line came loose to begin with. If the primer bulb is pumped too much would this cause it to come loose, thanks in advance
115 yamaha
Sounds like the tie wrap just failed from heat / age, etc...
I'd replace the zip ties at least.
As for the hoses, I'd personally stick with OEM.
Note, Yamaha does make a zip tie that's CURVED on the INSIDE for small fuel lines. IE, less chance for leakage/fits a little better..
http://www.boats.net/parts/search/Ya...UEL/parts.html
.Last edited by TownsendsFJR1300; 05-27-2017, 06:52 PM.Scott
Originally posted by countrytn View Postturns out the fuel line came loose from the bottom carb. The line that came loose is a pre bent that goes on bottom of carb. It had a tye wrap on it but was broken when found off of carb.
So you'll have to clarify what came loose. If you found a broken "tye wrap", then I would think the rubber fuel hose came off the metal fuel tube. But this rubber hose is not "a line that is pre bent", as you stated. The metal tube is pre bent.
If the metal tube itself had broken off carb then you wouldn't have found a broken tie wrap. The tie wrap would be secured over the rubber hose, which would still be secured over the metal tube.Jason
