Boscoe or Rodbolt I had asked a few days ago about a charging issue where my battery voltage was dropping to 11.5 volts or so and at other times charging ok.
In starting to look at the issue today after starting and running the engine several times today it always started charging above 13 volts and going up to about 14.5 or.6. however when going back to the engine and starting to look at the rectifier to start to check its output it was very hot to the touch. How warm does the rectifier usually get? Do not have any type of temp monitor to really check.
Sorry this is on a F115TLRC 2004.
