This has probably been covered many times but I couldn't find the exact answer to my question when searching.
So here goes:
I have just re-powered my boat with a 2004 F150AET. The engine came with a new 703 con*****er and multi-function gauges (tach and speedo). The engine has 2 plugs for the trim/oil harness. Looking at the tach it looks like it's from a later model year engine (only has one plug on the back). I also have a trim oil harness which has 2 plugs at each end.
Both gauges indicate as expected but my trim indicator top bar flashes i.e. not receiving a trim sender signal, which makes sense if the second plug is not connected at the back of the tach.
So my question is is there a way of getting the trim function to read on the gauge? Can I use the existing harness 'spare' plug wires and splice in to the tach wires or do I have to buy an adapter harness?
Cheers
So here goes:
Cheers
