2005 Yamaha F40 4 stroke, carb.
Issue A: Before today, when you came back to neutral the engine would make a clicking sound (almost as if it wasn't fully in neutral or some gear adjustment was out). If you tapped the throttle on the remote backward it would stop. Again, seemingly as if it's slightly out of whack / not coming back far enough. Any ideas here? Is there some time of linkage adjustment ? I replaced the plate lock (p/n 703-48245-00-00) in the 703 remote last year after the original broke (long story, big limb fell out of tree while running in flooded backwater). As I recall, the "clicking" when going into neutral however existed before I replaced this part.
Issue B: Just started today. Got the boat out for the first time in a month or so. Boat cranked fine and idled fine (slightly rough at the beginning, but I attributed to new prop I added yesterday). At any rate, the boat idles fine, however, once you increase RPM's (forward or reverse), then come back towards neutral, the RPM's stay higher than normal. They don't seem to be following the throttle back down. If you let it rest in gear right before crossing into neutral, it will eventually idle down to the normal range. It SEEMS as if something is just sluggish to move, but eventually corrects itself, I'm just not sure where to begin to clean/lubricate. Again, the boat has set up off and on over the winter, and has had limited use this spring. Any ideas?
