That ^^ AND drain the bowl (drain bolt) catching what comes out in a small clean can..You want to inspect what comes out.
A small spritz of air thru that drain may loosen it as well.
Rare, but does happen, the float itself leaks and doesn't float anymore-thus the flooding as the float is ALWAYS open..
At least you only have TWO carbs, should be a bit easier:
(Doesn't show the linkage so a pic posted here would be a help)
http://www.boats.net/parts/search/Ya...TOR/parts.html
