Water pump flow
  • Water pump flow
    I recently had new water pumps, thermostats, sensors, and popit valves replaced on my 1996 150 TXRU and am experiencing a water flow issue at mid-range rpm activating the sensors due to temp increase. no issues from idle to 2700, or past 4000 rpm, however, I loose flow in-between that range. I flushed the motors with salt away thinking it might be a crud issue.....Any thoughts???
    20 year old motor. It very well may be partially clogged.
      do some research on Rydlyme marine descaler, some have reported good results.
      it that does not help then pulling heads ,covers, and exhaust plates to manual clean
        has anything been added to the hull?
        are you sure the water screens got installed properly?
