'92. 85hp lower unit swap
  • '92. 85hp lower unit swap
    Have '92 85hp with a bad lower unit. Trying to find a replacement has been difficult. Is there a cross reference chart available that would show what, if any, other year/model lower units would bolt up?
    Thanks, Dan
    Need the complete model identity. I suspect this is a C85 but...
      yes, it is a C85
        The part (upper casing) that the C85 lower unit attaches to is used on 1984 ~ 1993 C85 and 90 HP models.
        688-45111-03-EK YAMAHA CASING, UPPER
        So any lower unit from these motors should plug and play.
        Now the 1993 90TLRR lower unit, part number 6H1-45300-13-EK, has been replaced by a -14-EK, a -15EK and a -16EK lower unit. Any of these lower units should plug and play on your model motor.
          Thank you very much!!!
