any idea how much an entire unit costs then? I have a reason for asking.
F150 balancer experiment ends
Originally posted by panasonic View Postany idea how much an entire unit costs then? I have a reason for asking.
2006 and Later F150TXR Yamaha Outboard CYLINDER CRANKCASE 1 Diagram and PartsScott
I was thinking that someone would have a repair service for those. Send in your old one and have repaired or exchanged. using steel gears instead of plastic ones. The gears would not be expensive to have made if buying in bulk. The Labour to change them out....I don't know.
No money to be made if they are only $400.00 for the whole part...I guess.
Originally posted by panasonic View PostI was thinking that someone would have a repair service for those. Send in your old one and have repaired or exchanged. using steel gears instead of plastic ones. The gears would not be expensive to have made if buying in bulk. The Labour to change them out....I don't know.
Plastic/composite INSIDE, working a heavy unit, just plain dumb..Scott
Just for information sake, if the balancer is disassembled for what ever reason, the ARP TTY bolts that fasten the bearing caps are NOT an off the shelf item from ARP. I have been down that path and had email confirmation from ARP that those specific size, thread TPI and length bolts are not available!..... and if you look at the parts list from Yamaha, all parts that make up the balancer are NOT available seperately. Ya gotta buy the whole unit
I looked at CNC machining and case hardening new shafts with steel gears but the hurdle to get over was the bolts. There are other design bolts that could do the job, but the biggest concern i had with that idea was the amount of counter acting vibration the balancer creates can either work loose those bolts or snap them at the head. That was not a risk i was willing to take nor re using the old bolts.
Replacing with a new balancer from yamaha looks like the only solution at this stage Damn shame really.
Cheers
Scotty
Originally posted by scottcmb1965 View PostJust for information sake, if the balancer is disassembled for what ever reason, the ARP TTY bolts that fasten the bearing caps are NOT an off the shelf item from ARP. I have been down that path and had email confirmation from ARP that those specific size, thread TPI and length bolts are not available!..... and if you look at the parts list from Yamaha, all parts that make up the balancer are NOT available seperately. Ya gotta buy the whole unit
Cheers
Scotty
adult imagecertificity.com
In the world of bolts, they appear to be grade 20. They are brutally strong. I may keep them just for the hell of it. I thing the aluminum case would melt away before anything happened to these. Like you said, they are unique, certainly in appearance.
Cheers
Scotty
Let me try this without my pic.
Those 8 black bolts are brutal. No way they will fail. If bolts are graded 1-10 for strength, they are 20. I may save them just for the hell of it.
Cheers
Scotty
