Normal temps of heads on ox66 250HP **pics**
  • Normal temps of heads on ox66 250HP **pics**
    I ran my 2001 Yamaha 250 today for about 6 minutes then pulled the cowling to examine. I wanted to make sure all seals were good and that the VRO was pumping well. All was well in that department.
    I did notice that my clinders were pretty warm though. That might be normal, but I though I would run this past you guys.
    Upon putting my hands on the cylinders this is what I found:
    Bottom Cylinders: Mild warm to touch
    Middle Cylinders: Medium hot - could touch about 8 seconds then too hot
    Top Cylinders: Hot - could touch them about 5 seconds then too hot.
    Is this normal when running boat for 6 minutes at 3500RPM's?
    Also,
    on the right side of the motor, I have 3 wires. I beleive they go to guages. There is also a harness. Do you guys recognize these wires? I'd like to hook them up if possible.
