I have a 8hp 2stroke outboard. The engine starts, but will not keep running. If I squeeze the fuel bulb in the fuel line between the take and the engine every 5 to 10 seconds, the engine runs fine, for as long as I keep squeezing the bulb. If I hold the fuel tank and fuel line higher than the engine 'gravity feed', the engine runs fine.
I suspect a fuel pump issue? Any help with the diagnosis and what I need to do to repair would be appreciated.
S/V Mar-a-Lago
S/V Mar-a-Lago
