Yamaha sho 250
  • Yamaha sho 250
    Trim and Tilt not working, fuse seam ok, clicking sound at tilt control panel while trying to raise motor up or down. Help please
    Will it crank and start?
      where is this control panel that is make the clicking noise?
      clicking noise is usually at the T&T relay on the motor.
      If T&T relay is sending voltage to the T&T motor but it does not turn, then either the motor is bad,brushes, or relay, or wires/connections
        Do a bit of testing...unbolt the t/t motor leads at the t/t relay. On a 2 wire, ground 1 lead and put the other on a hot terminal, then reverse them. If the motor works it's good. Use a test light at the relay where these 2 wires attached, test 1 at a time, each terminal should alternate back and forth ground/ hot depending on which direction the t/t switch , up/down is pushed.
