Ausnoelm: According to the wiring diagram the negative battery terminal goes to the motor and then a ground wire goes out the main connector between the boat and motor.
Panasonic: No don't know anyone I can trade with, unfortunitly.
Robolt17: Yes, it does have a red stator.
I checked the pulser coil and charging coil at the CDI connector while cranking and both signals were there although both were higher than the manual by about 20%. I also check the kill switch at the CDI and it was working ok.
99yam40: I built a peak detector circuit to check voltages. The pulser and charging coils both read high (about 20%)and the CDI output to the coil read way low. Can't really use the manual for voltages but it does say 2 signals are there and one is barely there.
