f80tlra wiring diagram?
  • f80tlra wiring diagram?
    I recently purchased a boat with a f80tlra. It runs fine but won't shut of when warm. I found article http://www.yamahaoutboardparts.com/f...f-th23386.html which helps but I also have multiple gauge issues. Upon inspection of the engine wiring I also found the green wire on the harness unplugged, Tach I assume. Oil light is also on on the ignition switch. I would like to find a wiring diagram so I could easily verify the existing wiring. I've googled it but so far have came up empty handed. Can someone point me in the right direction.
    Wiring diagram is in the back of the service manual.
    https://yamahapubs.com/results.php?c...80TLRA&lang=en
