One of my two HPDI 2 stroke 200hp motors is pushing steam (not oil smoke) out of idle exhaust, at the dock. Changed both thermostats, and checked head temp with infrared pyrometer. No apparent issue. Help! Also, same engine appears to be missing in Drive, at about 900 rpm or so, when running on 6 cylinders. Help! Again!
Also, I pulled all 6 plugs, and they all look the same. A little sooty and slightly oily, but not one any different from the rest...... And I should add that this is relative to the starboard engine....which idles/runs great, with no steam/smoke from the exhaust....................... Thanks again, all....ANY ADVICE or INSIGHT would be appreciated. Thank you.
