Let's use a thermoswitch as the example circuit. You suspect the high temp alarm is giving a false positive. Could someone detail for me the electrical pathway of this circuit when the engine temp is normal and when high temp is detected.
If need be for this particular example, assume the load wire is BLK/GREY and ground is BLK.
