I guess the actual Yamaha SHOP manual on how to test it (as posted previously from the manual) should be simply ignored, shredded.
Heck they only designed the engine. What do they (Yamaha) know about testing a LU???
If Yamaha wanted it to be tested using vacuum, it'd be posted..
Note, I watched a Yamaha Master tech pressure test my LU, 10 PSI, for 10 seconds (after a drive shaft seal replacement) THREE and half years ago. NO other tests.. LU oil is still g0lden after each year (changed yearly)..
