Hi,
I own a 2015 yamaha f90 - use it quite frequently - at least once a week.
A regulator/rectifier failed on the motor and it stopped charging the battery (no smoke or overheating signs on the rectifier).
I replaced the regulator/rectifier.
Then the trim/tilt switch on the outboard failed.
The new regulator/rectifier has just failed again!!
I have a new trim/tilt switch ordered.
I checked and cleaned the engine and battery connections (they where clean anyway)
To the boat battery (new battery - less then 12 months old - dual purpose 12V starting/deep cycle battery) I have:
- Yamaha F90 motor wires
- Rule Bilge 1100 gpm wires (not fused)
- Basic Stereo wires (in-line fused) - stays in stand-by mode when motor is off
- After market GPS (in-line fused) - draws power even when motor is off as it gives update on location
- Boat lights wires
All wires tightened down with wing nuts - tightened with pliers (always seem to be tight).
- Boat lights wires
