Hello to all!!
I have a 2005 200 HPDI that has a low rpm all of a sudden, runs like a top on plane but once you get it warm I has idle problems.
That being said we have tested everything on motor, idle interrupter switch when touched will suddenly kill the motor. When removed from the scenario boat seems to perform just fine???
Thoughts??
Also this motor has bad compression in cylinders one and two, pulled the head and all looks great inside so ran a decarbonization and no help. Further investigation leads to discovery of pre-ignition spotting on a couple of the pistons. What could be doing this??
Thanks!!!!
Thoughts??
Thanks!!!!
