squealing t/t unit
    Rodbolt, can you give him info on jumping the T&T motor while on the bench
      Did you fix the powerhead or find a replacement?
        Replacement sx225txrz. Trim pump worked prior to the cash hitting his hand, but did sound a bit off. Then started acting up with intermittent down with solenoid clicking. Pump motor was filled with corrosion and a lot of white powder. Cleaned it up and got it working, but still was getting the intermittent down. With a test light on the solenoid, the up power wire that should go ground was only doing it occasionally. The power signal to both hot wires was working properly. So ordered a t/t relay. Got a green and blue hot for up and down. black for ground. white one don't know what it does, it's not a ground
        • #19
          Did a clean up on the starter motor, resealed, installed a new starter relay. Everything works as it should, t/t switch on the side of motor works.
          For some reason my binnacle t/t switch works fine but now up is down, and down is up. Apparently the binnacle t/t switch runs through the 10 pin cannon.
          Could have sworn the binnacle was working correctly before I tore into this.
          • #20
            Sounds like two of the 4 wires are mixed.
            Not at the engine switch, but elsewhere. IDK if the wires can be swapped at the relay. Someone else will have to chime in... Not a biggon thou..
            Swapping them after you get the correct electrical diagram should be easy..
            • #21
              Originally posted by CaptSolo
              t/t motors wear out and fail. I've had to replace all three of my 12 year old T/T motors of F225 tilt motors in the last 6 months. I went with an AM for 1/4 the cost of OEM. Relays all still work.... click.. click..
              Cleaning the T/T motor up and expecting it to last from what I've read here is a waste of time and money.
              Original t/t is a quality piece. Not much in there to wear out. Magnets on the casing aren't going any where. Armature winding is all brass and tough . brushes are replaceable . There's probably 25 replaceable parts that are available for that motor . Just got mine rejuvenated with less than $20 worth of parts
              • #22
                Get it working correctly?
                And the squeaking?
                • #23
                  I WOULD GREASE THE PINS THAT HOLD THE TILT CYLINDER AND THE T&T ASSEMBLY.. there ARE ALSO TWO VERY SMALL FILTER UNDER THE PUMP THAT MAY BE PARTIALLY CLOGGED. yOU CAN GET A BREAK DOWN ON BOATS.NET FOR YOUR PUMP ANF IT WILL SHOW THEM..iT IS ALSO A GREAT SITE FOR OEM PARTS.
                  • #24
                    Squeaking gone after cleaning inside of t/t motor, big time mess in there. Working sweet now
                    • #25
                      How'd you fix the "wrong direction button"?
                      Engine up and running yet?
                      • #26
                        He is not going to admit what he wired up wrong
                        • #27
                          Well, I never heard of a 4 wire yamaha T&T system, thought all were just the two wires.
                          I'm sure he tells...
                          I'd like to yank that failed piston out of the old engine thou, just for S&G's. If that block isn't damaged, might be worth messing with..
                          • #28
                            Impossible to wire wrong....blue,green,black and white..Relay is color coded.
                            Up/down switch on motor was working in proper direction, it was the binnacle that was working in reverse. So I switched blue to green at the relay and turned the cowl switch upside down.
                            All maintenance done, headed to yacht club ramp shortly.
                            I would have given you that block if you asked, stripped it, and junk man removed it. Too old and corroded for me
                            • #29
                              Thanks...................
                              • #30
                                Motor ran flawlessly and 5 mph faster than older one. Tops of pistons looked carboned up, but with my WOT driving style, carbon will be gone before long.
                                Got me a $40 parking ticking at yacht club boat parking. No signage saying anything about paying. I pay enough taxes in this town....total BS
                                You can have a crack at this one when I blow it up. Not really sure how much WOT these motors can handle?
