Rodbolt, can you give him info on jumping the T&T motor while on the bench
squealing t/t unit
Replacement sx225txrz. Trim pump worked prior to the cash hitting his hand, but did sound a bit off. Then started acting up with intermittent down with solenoid clicking. Pump motor was filled with corrosion and a lot of white powder. Cleaned it up and got it working, but still was getting the intermittent down. With a test light on the solenoid, the up power wire that should go ground was only doing it occasionally. The power signal to both hot wires was working properly. So ordered a t/t relay. Got a green and blue hot for up and down. black for ground. white one don't know what it does, it's not a groundLast edited by scofflaw; 03-28-2017, 08:06 AM.
Did a clean up on the starter motor, resealed, installed a new starter relay. Everything works as it should, t/t switch on the side of motor works.
For some reason my binnacle t/t switch works fine but now up is down, and down is up. Apparently the binnacle t/t switch runs through the 10 pin cannon.
Could have sworn the binnacle was working correctly before I tore into this.
Originally posted by scofflaw View PostDid a clean up on the starter motor, resealed, installed a new starter relay. Everything works as it should, t/t switch on the side of motor works.
Not at the engine switch, but elsewhere. IDK if the wires can be swapped at the relay. Someone else will have to chime in... Not a biggon thou..
Swapping them after you get the correct electrical diagram should be easy..Scott
Originally posted by CaptSolot/t motors wear out and fail. I've had to replace all three of my 12 year old T/T motors of F225 tilt motors in the last 6 months. I went with an AM for 1/4 the cost of OEM. Relays all still work.... click.. click..
Cleaning the T/T motor up and expecting it to last from what I've read here is a waste of time and money.
I WOULD GREASE THE PINS THAT HOLD THE TILT CYLINDER AND THE T&T ASSEMBLY.. there ARE ALSO TWO VERY SMALL FILTER UNDER THE PUMP THAT MAY BE PARTIALLY CLOGGED. yOU CAN GET A BREAK DOWN ON BOATS.NET FOR YOUR PUMP ANF IT WILL SHOW THEM..iT IS ALSO A GREAT SITE FOR OEM PARTS.
Originally posted by 99yam40 View PostHe is not going to admit what he wired up wrong
I'm sure he tells...
I'd like to yank that failed piston out of the old engine thou, just for S&G's. If that block isn't damaged, might be worth messing with..Scott
Impossible to wire wrong....blue,green,black and white..Relay is color coded.
Up/down switch on motor was working in proper direction, it was the binnacle that was working in reverse. So I switched blue to green at the relay and turned the cowl switch upside down.
All maintenance done, headed to yacht club ramp shortly.
I would have given you that block if you asked, stripped it, and junk man removed it. Too old and corroded for meLast edited by scofflaw; 04-01-2017, 12:29 PM.
Motor ran flawlessly and 5 mph faster than older one. Tops of pistons looked carboned up, but with my WOT driving style, carbon will be gone before long.
Got me a $40 parking ticking at yacht club boat parking. No signage saying anything about paying. I pay enough taxes in this town....total BS
You can have a crack at this one when I blow it up. Not really sure how much WOT these motors can handle?
