i have a 2000 F200 that has oil coming from the weep hole at the top of the gearcase and it is engine oil ,not gearlube. gimme some suggestions
Yamaha F200TXRY oil leak
this may be a possibility:
ALL F150, F200, F225, & F250 MODELS THROUGH 3/31/2008 PRODUCTION
A Yamaha-specific repair sleeve has been developed to repair seal wear on the F150, F200, F225 and F250 crankshafts. These models utilize an oil pump that is driven by the lower end of the crankshaft. Oil leakage is con*****ed by a double-lip oil seal in the oil pump housing. Seal wear grooves may develop on the crankshaft seal surface due to environmental conditions and usage patterns leading to oil leakage down the driveshaft. To minimize repair time and expense, the Yamaha-specific repair sleeve for this specialized application can be installed on the crankshaft to provide a new seal surface without requiring replacement of the crankshaft.
https://youtu.be/p1aM0Kb9qc0
