Posted for Karljs1
    Check the fuse holder for tightness and all connections from the battery to the fuel pump for the presence of corrosion and security. If the relay is opening causing power to be lost then check the wiring to the relay. Could be the relay failing internally as well.
      Thanks, on it!
