My 2007 Yamaha 80 hp jet (115 power head) very hard to start when cold, fine after that and runs good. I suspect the auto electric choke maybe not working. Should I hear it click or something when the key switch is on and pushed in, I am not even sure just where to located the choke and assume it has a solenoid that I should hear engage. I don't think there is a manual choke on it. Any advise would be appreciated for checking this out. Thanks for welcoming me to this forum.
2007 80 hp jet very hard to start when cold
Is the an out board engine with a jet drive? And is it 80 HP or 115, don't think it can both...There is no 80 HP listed for the US.. Where are you located?
Model #? Should be 3 or 4 letters..
2 or 4 stroke?
Which one of these?: http://www.boats.net/parts/search/Ya...ter/parts.htmlLast edited by TownsendsFJR1300; 03-22-2017, 09:42 PM.Scott
It says 80 hp on the motor cover and it is an outboard jet drive. I just think it is the same power head as the 115 hp and they just derate the hp when there is a jet drive in stead of a prop drive, though I could be mistaken. It is a 4 stroke with no tiller handle, but controls are by the steering wheel. Thanks
I am in Washington state, forgot to add that. Also I found the motor # F115TJR manufactured in 04/06.Last edited by Just like to fish; 03-22-2017, 10:10 PM.
Welcome.
Your model is fuel injected. The Primestart system within the computer adds extra fuel to facilitate a cold start. You won't hear a sound. Yamaha uses electrons in that model that are very quiet.
The motor uses various sensors to detect air temperature and engine block temperature. Based on inputs from these sensors the computer determines how much extra gasoline to add. Perhaps one of your sensors is not correctly telling the computer that it is cold.
Originally posted by TownsendsFJR1300 View PostIs the an out board engine with a jet drive? And is it 80 HP or 115, don't think it can both...There is no 80 HP listed for the US.. Where are you located?
2 or 4 stroke?
Which one of these?: 2006 and Later Yamaha Outboard Parts
Originally posted by boscoe99 View PostA Yamaha jet drive outboard can be known as a 115/80. 115 for the horse power of the engine and the equivalent of 80 HP from the jet drive unit. Jet drives are fairly inefficient.
A regular, say F150 doesn't give HP spec's at the prop (their not counting drive-line drag) un-like the above engine...
Agreed the jet drive is less efficient BUT I would think there's more HP loss on a propped engine. Drive shaft, LU, 90wt oil, etc vs non of that on the jet drive...
I guess (doesn't sound right) the jet pump takes MUCH more HP (equivalent to 35 HP??)Last edited by TownsendsFJR1300; 03-23-2017, 08:26 AM.Scott
With a propeller driven outboard motor it is understood that the HP rating is at the propeller shaft.
With a jet drive outboard motor it is understood that the HP is at the jet pump.
Big big difference between the two.
Here is Yams lineup of jet drive motors. They make an effort to be clear that a jet drive F150 is not going to have anywhere near the thrust that a propeller driven F150 will have. Many in the past bought an F150 jet drive and were then disappointed with its thrust.
Originally posted by Just like to fish View PostBOSCOE99,
So are you telling me that my ignition switch, push to choke actually does nothing for me because the computer just uses sensors to add the enrichner fuel when the sensors say the engine is cold.
You did not say what model motor you have. If it is a Yam USA model then it has got to be fuel injected since all F115's/80's have been fuel injected since 2001.
Originally posted by boscoe99 View PostYou did not say what model motor you have. If it is a Yam USA model then it has got to be fuel injected since all F115's/80's have been fuel injected since 2001.
(Interesting about the output #'s.... thanks)Scott
***, I didn't realize there was THAT much drop in HP!
EDIT: Apparently "w o w" is bad word on this forum!
For what it's worth, stern drive boat manufacturer's (Sea Ray, Chaparral, Bayliner, etc) USED to advertise HP the same way. They would advertise HP at the crank, not the prop. Sometimes they did both, but usually they just advertised the higher HP. Somewhere around the mid-90's they stopped doing that and now only advertise prop HP. Whether it was the engine manufacturer's choice, the boat manufacturer's choice, or some combo there of, I don't know.Last edited by DennisG01; 03-23-2017, 01:49 PM.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
