2012 F350 Injector maintenance
    I sent a message to a fuel injector man (Brucato Fuel Injector Company) on another site that I frequent and asked him about this. When he gives me the answer I will post it and appear to be smarter than I really am.
    I will guess ahead of time that it is a sealed unit and can be submerged. We shall see.
    Thank you!!
      Here is his reply. I read this to mean that the electrical side of the injector should not be dunked in the cleaning fluid.
      "Yes, up to the connector. We let them cycle or pulse for minimum of 30 min and then injector should be back flushed to remove any remaining contamination. Injector must be cycled or running and flowing to warm it up to operating temp for minimum of 4 minutes before flow testing. Flow testing solution must be temperature control to a target specific gravity. Without these parameters and several others and not knowing what the injector is supposed to flow you just guessing or assuming that the injector is flowing required amount."
        Thanks, makes sense...
