Solenoid F115
  • Solenoid F115
    Can anyone list the part number for a 2004 F115 TLRD starter solenoid?
    Is item 22 what you are seeking?
    2006 and Later F115TXR Yamaha Outboard STARTING MOTOR Diagram and Parts
      Originally posted by Jason2tpa
      The last letter of the model you listed (D) doesn't align with the year you listed ('04).
      2004 F115TLRC
      2005 F115TLRD
      And do you mean the starter relay?
      Label plate cites 8/04 but codes indicates 2005.
      That appears to be the one. Here's what I'm referring to.
        I is a 2005 built in 2004
          I thought you solved your problem by replacing the relay!
          still having trouble?
          that solenoid is an expensive part - almost as much as the whole starter!
          or you could buy several used starters....
          when i was a young lad, those solenoids were "serviceable" -
          you could take the contacts out, give them a half turn and re-install good as new...
            Did they even have solenoids that long ago? Back when you were young lad that is.
              ...when i was a young lad, those solenoids were "serviceable" -
              I thought so too but after replacing the relay the gremlin came back. I ended up buying a starter and problem solved.
              Thought I'd buy and replace the solenoid then have a spare starter .
              As for back in the day...I too would remove, turn and reinstall
