I love the bucket analogy - so true!
Voltage drop is a great test to locate/narrow down where a problem is.
You mentioned 13.1V at the battery. With that reading, I assume it was right after turning the charger/engine off? Even a new battery won't show that high of a voltage at rest. Check the resting voltage after sitting for a day or two, or after a quick attempt at starting the engine. I agree that there's most likely something causing extra resistance, but don't rule out the batteries - they are a variable and you may want to eliminate them from the list by getting them checked out again.
If you haven't removed, cleaned, reinstalled (tight) ALL connections, both +/-, from battery to engine, do that too. Don't assume they are clean by just looking at them.
Check your battery switch, as well - connections (clean and tight) on the back side. They're generally a very reliable piece of equipment, but they do occasionally fail internally, too.
