1988 Yamaha 130 dies at transition to high RPM
  • #31
    Sorry, it did not come "off of" a Chev, but it may have come "off" a Chev, that being correct grammar.
    • #32
      Your kidding write?
      And "Chev" is a Chevrolet...
      • #33
        Your kidding write?
        Our buddy from down under never really adds much to topics.
        Bitches alot though....
        • #34
          seems being as far apart as we are, we do speak a little differently.
          but we can understand each other most of the time
          • #35
            yes, ur writ. short of sertin part nams, most geet there pont acros..
            • #36
              Exactly... If its a quadrajet, it probably wouldn't fit...
              Neither would a carburetor for an R4360. It is about the size of an F150's block.
              R4360 as in 4,360 cubic inches. As in 71,447 cc's for the metric minded folks.
              Imagine the size of the ultrasonic cleaner for that bad boy.
              Now if one carburetor could feed 28 cylinders back in the 30's, why does Yamaha need four of them to feed four cylinders?
              • #37
                You noticed also.
                • #38
                  I think this is the motor that had to be started in a very particular manner. If not, every single plug would be fouled. I think there were two per cylinder. There was one on display in Pensacola.
                  Nope not Pensacola. Air Force Museum Eglin AFB. Not too far from Pcola..
                  US Navy didn't need this beast of a motor
                  • #39
                    KISS, especially when your at 30,000' high...
                    Probably a 1,500 RPM limit engine, dual ignition, etc my be my bet..
                    • #40
                      cause Yamaha has to deal with ease of starting for some folks,smooth idle and a smooth transition from idle to WOT.
                      • #41
                        but if it was british they could use 28 SU carbs .
                        • #42
                          I wonder if bitching about someone bitching is bitching?? Yes, it is.....
                          • #43
                            more like if it came off of a chevy V8 or an automotive motor, it will not fit
                            According to others, you actually mean Chevrolet
                            • #44
                              Anyway, enough of that frivolity, you need to clean the carb, as mentioned several times now.
                              • #45
                                Any updates???
