My Yamaha 130 dies when transitioning from 1600 RPM to high RPMs. Idle is fine, runs great at high RPMs (3800) but it dies during transition UNLESS I hit the choke first. If I hit the flick the choke the transition is perfect. If I do not hit the choke it bogs down and dies. I've cleaned the carbs and put in a new fuel pump but no luck. Any ideas?
1988 Yamaha 130 dies at transition to high RPM
Thanks for the response. Carb screw settings were double checked but not the cause. Engine runs great at the higher RPMs once the throttle is opened up and it gets past the transition point. If there was any debris, I would think the engine performance would be impaired which is not the case. What else is happening in the engine at the transition point that might cause the lack of a smooth transition?
Each carb uses two separate floats:
1988 130ETLG Yamaha Outboard CARBURETOR Diagram and Parts
Agreed, there's still crap in the carb.
Did you pull the main nozzle (part #17) and check all the holes that you could see light thru them?
Cleaning to some folks means spraying with carb cleaner. All the jets need to come out and physically inspected so that you can literally see light thru them....
If you did do all the above already, you may try dis-assembly again and either soaking in carb cleaner solution or using a sonic cleaner..Last edited by TownsendsFJR1300; 03-15-2017, 06:03 PM.Scott
Originally posted by rodbolt17 View Postbeats me.
I am 55 and have been rebuilding carbs since I was about 8 and have yet to use an ultra sonic cleaner.
back in the day we used a bowl of gas.
back in the day that chem dip was mean stuff.
I could dang near drink it now.
The larger carbs are MUCH easier than the tiny little guys as the orifices are much smaller, use a small primer built in bulb(under that bulb is a one way "valve" that IS inaccessible). If it's clogged, you cannot poke it or it's destroyed...
I posted here about buying a sonic cleaner and used it on a Poulan gas blower carb recently. Worked great, no issues. Mix was Simple Green /water, 50/50 mix.
You'd be surprised at the amount of crap (the outside was clean prior to going in the tub) that was found on the bottom of the cleaner, once done.
Any tool that makes the job easier and more effective, I'm in for it.. Wish I had one years ago...
**While on the subject, can a sonic cleaner (liquid), be used on an fuel injector? IE, can an injector be soaked or will it damage the internal electrics?Scott
Cleaners are OK if there is just "stuff" in the carbs, but it would want to be a pretty good ulta sonic cleaner to remove a piece of grit from a jet! lots of jets and passages get blocked by a single grain of dirt, sprays and washing, and carbs "looking clean" will not fix it.
Ultrasonic cleaners can be useful when there is "plaque" build up within a very tiny passageway. Not all carburetors need to be cleaned using an ultrasonic cleaner. But some do. How can it be determined which need the ultrasonic cleaner and which do not?
Originally posted by boscoe99 View PostUltrasonic cleaners can be useful when there is "plaque" build up within a very tiny passageway. Not all carburetors need to be cleaned using an ultrasonic cleaner. But some do. How can it be determined which need the ultrasonic cleaner and which do not?
IE, a "do over"..
If I have a tool in my arsenal that can help me, I'm going to use it.
To each his own...Scott
Originally posted by ausnoelm View PostCleaners are OK if there is just "stuff" in the carbs, but it would want to be a pretty good ulta sonic cleaner to remove a piece of grit from a jet! lots of jets and passages get blocked by a single grain of dirt, sprays and washing, and carbs "looking clean" will not fix it.
The carb is STILL DIS-ASSEMBLED, the jets removed, etc. Then put in the machine. Your still doing a visual inspection once done. You also have to give it a spray to remove your cleaner...
IMO, it's more for the area's you CANNOT get to...Scott
Originally posted by usna1970 View PostThanks for the response. Carb screw settings were double checked but not the cause. Engine runs great at the higher RPMs once the throttle is opened up and it gets past the transition point. If there was any debris, I would think the engine performance would be impaired which is not the case. What else is happening in the engine at the transition point that might cause the lack of a smooth transition?
I addressed the nozzle in post #7 along with a link....Last edited by TownsendsFJR1300; 03-17-2017, 07:16 AM.Scott
Originally posted by rodbolt17 View Postjust be careful.
not all main nozzles( emulsion tubes) are removable.
would not be the first monkey destroyed carb I ever replaced.
there is really never a reason to remove that exposed nozzle.Scott
