OK F150TXR (and LF150TXR) 2010 & 2008 models. (250 hrs)
Getting ready to do the VST filter thing for the first time and while waiting for the parts to get here I thought I would go out and go over the procedure while actually viewing the motor in person. Bought the boat new in 2010.
Used information I got off SIMS of a post off another site as a guide. (you all probably know the post) Seems simple enough.
First thing I noticed was one of the 10mm bolts that holds on the front intake was missing! Looked below in motor housing to see if it was down there but couldn't see it. So that's one bolt I have to buy...lol
It doesn't look so hard so all I need to do is find out the torques of the intake bolts for when I reassemble everything. Went to the service manual and could not find them. VST mounting bolts-yes, throttle body mounting bolts-yes, Intake (front or rear) manifold bolts-NOT THERE! (at least that I could find)
Also noticed in the instructional post they stated 6 12mm bolts that hold on the rear intake (they did put a ? though) but it appears to be only 5.
I wonder how the one bolt went missing or if the factory just got in a hurry that day?
Anyway, can anybody tell me those torque specs?
