Laz200neto hpdi
    Is the rail pressure in spec?
    too high and it could be rich on all cylinders.
    maybe a leak , but you should be able to see that
    or injector leaking by
    Hopefully rodbolt will come on and give you some input
      Is it using more fuel than it once did? How long have you owned it?
      4000 lb boat dry weight? So maybe 5800lbs loaded?
      Wonder what prop is on the motor? May not be ideal. What is your max rpm?
