Laz200neto hpdi
  • Laz200neto hpdi
    Hello,
    I have a LZ200neto hpdi motor.
    It is using to much fuel, what would cause this to happen?
    While trying to solve this problem i had water in the fuel, now motor will cough and splutter over 2500 revs.
    Is it possible to get a fuel system diagramme for my motor, seems noone really knows much about these motors here in Newcastle Australia.
    I am trying to find what filters are on my motor and where they are.
    I have a water trap inline filter on the boat and know there is a water trap on the motor, but lost from there.
    Need help Rob
    Stop using the motor till it's fixed. Water in the fuel on hpdi is very bad.
    If your reving it in nuetral or even in gear when out of the water that's bad too.
    Check compression.
    Change all the fuel filters, change spark plugs, clean vst, change high pressure fuel pump filters.
    Get rid of all the bad fuel.
    A google search and you will find a ton of info on the hpdi motors.
    You can find parts breakdown here; 2004 LZ200TXRC Yamaha Outboard Parts
      there is a filter cup on the port side.
      there is a filter in the VST.
      there is a filter between the vst and the high pressure pump.
      there are two in the HP.
      there are filters in the injectors.
      does the alarm horn work ???????
        Originally posted by boscoe99
        Nice diagram. I din't realize oil was pumped into the VST as well as the crank area.
          I can't believe you can't find anyone who knows anything about them, Newcastle is a City, not a small town.
            re LZ200 NETO
            Thank you so much for your help.
            First thing we did was change fuel, check main tank.
            Trying to find right filters and someone to change them, I do not really want to do it myself, been pushing my limits enough with the renovation on my boat.
            But willing to help and learn
            my motor is on a pod,boat is moored 28 mariner flybridge, so many mechanics will not work on it while it is in the water/
            Also hard to find someone that knows these motors wel/
            l
            still would like to know if injector filters are the same as the high pressure pump filters?
            Originally posted by STILL TRYING View Post
            Hello,
            Need help Rob
              injectors and HP pump can be sent off to be worked on/cleaned. I am sure they will put new filters in them.
              you asked what could cause too much fuel to be used, I think a stuck open or leaking injector, leaking lines/or connection, too high of pressure maybe.
                the z 200 is a 2.6
                different pumps.
                at least for the US market.
                  re filters
                  Hello,
                  Thanks for your reply,
                  How much are the filters where you are,
                  They are very expensive in Australia.
                  Alarm does work, though seemed very late
                  Rob
                    mY MOTOR is liek a Woman, moody and unreliable
                    HelpPeople,
                    My motor decided it wanted to work again today, 4100rpm 20knots smooth.
                    Later back to normal over 2500rpm not good.
                    Really feels liek a fuel problem like previously discussed with several people.
                    So far I am checking fuel, checking water traps, going to replace VST fILTER, BUY SOME NEW INJECTOR FILTERS, and check HP pump.
                    would welcome any more imput to what else I can do please?
                    Hopeful Rob
                    P.S. Very frustrated Rob
                      What boat is this motor mounted to?
                      20kts at 4100rpm?
                      Never mind, see it now, 28 ft. Pretty heavy boat I imagine.
                      It seems these hpdi motors are extremely finicky about fuel. I am betting you are headed in the right direction.
                        re boat and motor
                        Inregeards to your question about the boat,
                        Yes it is now 28ft with the pod on,
                        But the baot is very light because the pod is full width bouyancy, only problem I have is the boat is too light in the ass when does not have a full load of fuel,
                        Wieghs abot 2 tonn an very easy to move through the water, my 8hp 4 stroke moves it at 4.5 knots easily.
                        Hope youhaving fun and enjoying life.
                        I am still trying to fix mymotor, no money at the moment hahahah
                        ROB
                        20kts at 4100rpm?
                          Curious, what is a pod?
                            A kind of extension to mount an outboard on, like a filled in bracket, here in Aus, they are called pods, why I don't know, they just are
                              200hp hpdi fuel consumption
                              Hello,
                              AFter replacing the VST filter motor runs so much better.
                              But still using to much fuel.
                              HAVE DONE A DIAgnostic and everything seems ok.
                              Would the lift pump cause extra fuel to be used?
                              Motor takes a little longer to fire now than before, could this be because of the fuel lift pump?
                              Interested in your views?
                              Rob
