I posted on the forum a couple weeks ago that I was going to attempt to rebuild the tilt trim unit on my 150 hp. Yamaha . I got some very helpful advise from members ! Thanks . Well my parts came in and I put everything back together, last night I added fluid to the trim cylinders before capping them and filled the reservoir . I followed the instructions shown in a you tube video on bleeding the system . After several fills and runs through the up and down range I still have an issue. When I raise the motor up and switch to lower it is stuck and won't go down , if I raise on the outboard manually while holding the down switch the motor lowers but is ****ing on the way down ! Goes up fine !! Anyone have this problem or got any suggestions ?
Thanks, Mike
Thanks, Mike
