F150. If I was to unplug a lead on the sender what would I expect? Audible, visual and code?
Oil sender
Originally posted by fairdeal View PostI can't remember the details - but I had to go to some lengths to test my oil pressure alarm -
which seems now like simply unplugging it wouldn't get the job done....
with the above test? nothing would happen.
now use the resistor AND short the temp switch and it will work.
F motors that use a sensor and a switch must have both in agreement to operate the alarm system as designed.
f motors that use a simple switch just need the switch shorted.
F motors that use a sensor only you must do some math and go to radio shack and buy some resistors and fake the ECU.
myself,over the years, I have a known good oil pressure sensor.
so to test the alarm system on the oil I simply unplug the engine sensor,plug in my sensor and start the engine.
you could get fancy and hook up a little hand pump and gauge to that spare oil pressure unit and be able to pressure it up to different pressures while doing your test, but the low reading of no pressure will set off the alarm anyway so why do that unless you just want to see what pressures (over or under) will set the alarm
