The tilt trim unit on my 2001 150hp is leaking between the pump housing and the trim/tilt cylinders . Has anyone ever had this happen and if so how tough a repair is it for a shade tree mechanic .... The ATF has run down the outside of the transom and wetted the bottom paint, Am I correct in thinking this will damage the gel coat if not cleaned off ??
Thanks, Mike
Thanks, Mike
