I recently purchased a 1982 SeaCraft 20 with a 1987 Yamaha 200 ETXH (6G6). This is my first "big boat" and largest outboard.
last weekend I went to start it after it had been sitting for a month or two. Got it running and noticed no water coming out of tell tail (pisser), I turned the key off, and motor kept running, pulled kill lanyard...kept running, shut batteries off...kept running, finally pulled fuel line and eventually stopped. After some diagnosing of the harness etc.. turns out most likely the key switch. This however, is not the issue just the back story.
Figured I would start with water pump. I dropped the lower unit to replace water pump...easy...till I got to the woodruff key, dremel and a couple hours and finally got it out. I went to get new water pump kit, there seem to be several that could work on this motor. Ended up at West Marine with two parts...Sierra 18-3396-1 and 18-3311...here is where it gets weird...the 3311 is what the 'computer" says is the right part (problem was the only kit in stock was missing the actual impeller)...I somehow found the 18-3396-1 on their website and took a look at it. Side-by-side comparison appears that all parts are identical in each kit with the exception of the diameter of the hole in the tin cup, the 3311 is narrower that the 3396-1. I brought my old pump in to compare and the one I took off my motor matches the diameter of the 3396-1 (which according to the computer and other resources) technically inst the one for my motor.
So now I left asking a couple questions...
1. is the lower unit from a different motor?
2. Did someone put the wrong part in at some point in the past?
3. Did the manufacturer replace parts/part #'s over time.
4. If I go with the one that matches what I took off will there be an issue you could think of?
5. The hole diameter shouldn't matter as its only to get over/around shaft?
I also think there may be some "pieces" missing, when I disassembled there was not ring or washer/seal around drive shaft entering into water pump housing..I think there should be..can anyone confirm?
Sorry for the long winded story...any help/insight would be appreciated.
Ryan
Ryan
