Have a 50 HP, 50TLR, 2 stroke. Purchased with no history. Engine had been left to sit for a long while. I dumped 15 gal of gasoline and replaced with new fuel, drained the fuel bowls, replaced the fuel hose. Engine ran rough, hitting and missing. I cleaned and installed new kits in all 3 carbs, installed new fuel pump, rebuilt the primer assembly, installed new spark plugs, and installed new prime starter as the original was defective. Reset the pilot screws to 1 1/2 turns out.
Engine will start immediately but will misfire, probably on the #1(top) cylinder ever 4-5 cycles. Misfire seems to be on the compression stroke. When the misfire happens it almost kills the engine as it is firing against the normal turn of the engine. #2&3 plugs look good, light tan and dry. Top plug is black/tan and damp. I suspect the ignition is coming from the CDI but it is too early.
I am at a total loss. Any ideas really appreciated.
Thanks in advance.
Thanks in advance.
