milky oil
  • milky oil
    I have a 2007 15hp Yamaha 4 stroke that is getting water in the oil. I know it could be a head gasket but what else could it be? Thanks
    warped oil pan casting?
    or maybe - which would be best case -
    "stuck open" / missing thermostat ?
      not sure I follow how a stuck open or missing stat could cause water in oil
      Fuel probably but not water.
      OP cracked head/block, corrosion or bad gaskets on pan or other places
        Originally posted by CaptSolo
        HC! 15HP Yamaha. Even I could take the head off that and replace the gasket.
        I'll call BS on this. Dude, you refused to change thermostats...
