05 F115 issues
  • #31
    Sounds good.
    Thanks for your help.
    • #32
      My primer bulb never actually gets hard as it has on other boats. I am installing a new one while I am reworking the entire fuel system from tank to motor along with cleaning injectors and replacing all filters. but to answer your question, no as of yet i havent. I need to remove my yamaha fuel flow transducer and check/ replace it. Its not working anyway.
      • #33
        It does not.
        • #34
          let me look about the junk pile tomorrow.
          having never broken that part I do not know.
          but I do have a few parts VST's floating about.
          Any luck finding a replacement?
          • #35
            Got my injectors back yesterday from Mr. Injector!!! Two of them were clogged; they had a flow of 32 and 36 prior to cleaning. After cleaning they had a flow of 62 like they should. Hoping this was the problem all along, will be reassembling this weekend.
            • #36
              when I had injector clogging on my F90 I was surprised that an apparent small bit "off" made a huge difference.
              Before cleaning, my four tested at 88, 92, 92, and 96% of rated flow.
              Doesn't seem that bad, but the engine would idle only, and completely "break up" under load
              • #37
                I am hoping that's the case. I got her put back together yesterday and right now I am draining the fuel tank to get the ethanol gas out. I have plumbed a in portable tank just to test with and I am also waiting on my 2micron racor fuel filters to arrive. Keeping my fingers crossed that this is going to fix it. It's going to be a few days before I can run her but I will let y'all know how she does. Thanks for all the help.
                • #38
                  Wasn't there discussion about some engines that are unable to use 2 micron filters???
                  • #39
                    Its not clear me to what the value would be, anyway, although who would not feel "cleaner is better".
                    Rodbolt teaches us that, far downstream of that 2 or 10 micron filter canister,
                    both the LP and HP pumps generate "brush dust"
                    I have not seen it described in any Yamaha document,
                    but the "VST Filter" on my F225 - a screen, really -
                    appears to my eye to have "openings" of >200 micron across
                    I have not seen a size rating reported for the "basket filter" at the inlet of the fuel injectors - not gotten a look at them.
                    But seem to recall reading that orifices on a Port Injection nozzle are around 200 micron in diameter.
                    • #40
                      I assumed the 2 micron may be too restrictive in some's opinion. I can't recall the details.
                      • #41
                        There have been numerous people having success running the 2 micron with outboards up to 225 maybe more. It has a fuel flow of 60 GPH so its more than enough for a little 115. That being said, it will clog up sooner but I always keep a spare on the boat anyway.
                        • #42
                          Took her for a test ride and she runs so much better. I only had a temporary 6 gallon tank and the boats tank was empty and I was a little disappointed in the speed. I realize it's only a 115 on a 19' boat and that's half the problem. I was getting about 37mph at about 5700rpm. I was hoping for 40 with a light load but I don't see that happening. I am going to put 50gallons in this weekend and see how she does. Thanks again for y'all's help.
