F115 Command Link
  • F115 Command Link
    My pontoon has a 2004 Yamaha 115 TLRD 4 stroke. Does this have a command link connector?
    TLRD indicates it is an 05 model.
    I don't think the D model F115 was command link.
    an easy why to check is look for an unused 2 wire connector with a blue and a white wire.
    some of the 05 F150 motors that were supposedly cl would not work correctly.
      Will check, thx.
        If you have the CL wiring, you will have numerous "unused connectors" -
        this is the CL connector itself, (circa 2004)
        but as Rodbolt says,
        even if you have the harness, you may not have a CL capable ECU
        (that was the case for my F225)
          Thanks for that info.
          Dog gone storm/rain for then next 5 days so won't be going out to check the connector anytime soon .
