60 hp temp sensor
  • 60 hp temp sensor
    Hi guys,
    Newbie here with a question. How do you remove the temp sensor from the cylinder head? All I can see is the rubber plug with the 2 wires going in. It appears to be just pressed in there.
    Thanks for the help.
    Cheers,
    Cam
    Cam,
    Twist the rubber plug about 1/4 turn and then pull out. May need to run a thin piece of metal like a feeler gauge down the side of the plug to break the seal that is caused by the grease.
    Ken K
      Ken,
      many thanks came right out, just like you said.
      Cheers,
      Cam
