Plug 3 and plug 6 side by side. Looks like water/rust to me, thoughts? Where to check for entry points? Hot compression results are great so I want to get the issue resolved before any damage.
Yucky plug
There are many spark plug images on the web that help you to determine the nature of the problem, or if one exists. The images below were pulled from a website that gives a good analysis of NGK plugs; a spark plug 101 lesson. Weblink is here:
Spark Plugs Overview
The angles of the pictures you posted make it difficult to say. But they definitely do not look bad. The bottom plug in each picture looks a little carbon fouled, but not bad. How long have these plugs been used?
Jason
Originally posted by rodbolt17 View PostI cannot open the pictures.
what is the model # of said motor ??????
all I can deduce from the post is it is some kind of 6 cyl .
I am thinking pin hole in the head gasket as well. Just wanted to know if there were any other entry points.
Plugs and head gaskets are ~18 months old. I cleaned the plugs up, re gapped them, blew out cylinders then fogged w TCW3. Buttoned it back up and it fired/ran without a glitch (1 or so hour ride/fish).
Let me know if there is anywhere else to look before it goes on the trailer.
ÂÂÂÂÂ
