I'm finally pulling power head to check for debris from my destroyed balancer. I have the power head off , but can't figure out how to get access to the oil pan. The lower cowling is out of the way , but it looks like I need to remove the shift shaft to get the cover that is above the oil pan off. Have all but the last 2 bolts off , but the steering mechanism looks like its going to need to be pulled as well . I'm stumped , do I need to pull the lower unit off , and remove shaft that way ? 2006 scout and 2006 150 yamaha
access to oil pan
will try , all i'm trying to do is access the oil pickup so I can remove and clean the balancer debris from the screen , I don't physically need to remove the pan. The midsection will not come off without being able to pull the shift shaft through the top as there are 2 bolts that are under the steering brackets
I've got all the pics from the service manual . My brain is apparently not allowing me to see how to remove the midsection from the bracket. I've removed the nuts on the steering bracket , so my next move will be to manually raise the midsection/lower unit , and remove the lower unit , then the midsection
got everything apart , discovered oil pump had a chunk of balancer material , and the outer pump ring is cracked. Also discovered exhaust manifold extension had corroded through . Will need to drill out 1 bolt in oil pan where manifold bolt broke . Ordering parts tonight . I have searched all the parts pages on the Yamaha Outboards site and I cannot find the speedo hose. Does anyone have a part # for this ?
Originally posted by gsdanno1 View Postgot everything apart , discovered oil pump had a chunk of balancer material , and the outer pump ring is cracked. Also discovered exhaust manifold extension had corroded through . Will need to drill out 1 bolt in oil pan where manifold bolt broke . Ordering parts tonight . I have searched all the parts pages on the Yamaha Outboards site and I cannot find the speedo hose. Does anyone have a part # for this ?
2006 and Later F150TXR Yamaha Outboard UPPER CASING Diagram and Parts
Be sure to look under "Upper Casing" for your particular model # to be sure.Chuck,
Well that's just awesome , Thank You. I see why I couldn't find it , mine actually runs inside the casing with the steering rod so that's what I've been looking for . I have often wondered how it was able to work for the past 8 years with such a bind in it where I ran through the steering shaft opening. Thanks again . ( I did look in the correct place for my application , pn is the same , but it is # 33 , and not 31 for mine)
I was able to break apart the oil pump , and discovered 1 cracked gear , so I ordered a new pump. Damage from failed balancer : cracked oil pump gear , collapsed strainer . While apart , I noticed exhaust manifold extension was corroded through . Parts ordered , re assembly next week !
