There are usually multiple water pump kit options. If you're going to replace all of the water pump components, including the pump housing, wave washer, collar, etc...the parts # is: 61A-W0078-A3-00COMP
Here is a distributor webpage for this kit:
COMPLETE WATER PUMP REPAIR KIT
The parts # is the same as the standard kit with the addition of COMP after the last two digits. If you rather use boats.net as the distributor, call and ask if they have this complete kit. They probably do. If not, use the other option above.
